2 members (TUTS 59, 1 invisible), 152 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
Hi guys, I’m getting ready to align my front clip, and the hood support arch (?) underside at the rear of the hood does not have any kind of packing material or rubber strip between that arch and the underside of the hood- there is just a gap there that is about 1/8” thick. Is there something that belongs in there? I media blasted the hood myself, but I do not remember seeing anything in between those two pieces..
Any replies appreciated- thanks.
Dave
~ Dave
There was originally a tar impregnated piece of webbing (pad) in there between the hood skin and the back part of the support. It was glued to the hood skin. I think most of them have fallen out over the years.
Thanks Kevin. Maybe a piece of felt will work?
~ Dave
Dave,
This thread has info on that. Apparently it was foam rubber, not webbing. I have some stick on foam that I may try on my hood, assuming I can get the sticky side in place in the right position.
If you're going to use a foam, get closed cell that won't be as much a water trap.
Thanks guys!
~ Dave
