| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Hi guys, I’m getting ready to align my front clip, and the hood support arch (?) underside at the rear of the hood does not have any kind of packing material or rubber strip between that arch and the underside of the hood- there is just a gap there that is about 1/8” thick. Is there something that belongs in there? I media blasted the hood myself, but I do not remember seeing anything in between those two pieces..
Any replies appreciated- thanks.
Dave
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: May 2015 Posts: 11,073 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,073 | There was originally a tar impregnated piece of webbing (pad) in there between the hood skin and the back part of the support. It was glued to the hood skin. I think most of them have fallen out over the years. +
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Thanks Kevin. Maybe a piece of felt will work?
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: May 2015 Posts: 11,073 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,073 | Dave, This thread has info on that. Apparently it was foam rubber, not webbing. I have some stick on foam that I may try on my hood, assuming I can get the sticky side in place in the right position.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | If you're going to use a foam, get closed cell that won't be as much a water trap. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 |
