Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#1455395 06/17/2022 4:36 AM
Hi all,
Is it your experience that there is enough room to fit something like this under that headliner to keep the truck somewhat insulated? or maybe some 3MM Reflective Foam Insulation Shield?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Yes, and I have touched my bare roof before I used a similar product. Well worth the money.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Moderator, Electrical Bay
You can also use 3M foil-faced fiberglass made for HVAC work. But it all depends on what you're trying to accomplish. Fiberglass is good for noise reduction and heat reduction when installed correctly. Foil coated bubble wrap is more for heat control only. Install any foil faced product (preferably with an air space between the foil and as much of the roof metal as possible). This is why your A/C ducts look shiny...the foil is there to reflect heat away from them. If you have an air space between the metal and the foil, it will act like a radiant barrier, bouncing heat back to the roof metal. If you do not have any air space between the foil and the metal it will help with noise if the insulation was intended to do that, but the foil will just get hot and transmit heat into the cab. The exact same thing as wrapping a potato in foil and baking it. If you want a vivid demonstration of this, get an old incandescent light bulb and hold your hand about 2 inches from it while the bulb is burning. Your hand will become very hot very fast. Now stick a layer of common foil about halfway between your hand and the bulb...shiny side facing the bulb and see what happens. And finally if you're still curious wrap your hand tightly with foil and stick it on the light bulb. You'll know how that potato feels Good luck. Personally I use the 3M foil-faced HVAC insulation and let it lay on top of the headliner.
~ Jon
Actually, the insulation works both ways. The foil should be placed away from the roof metal, or it would be less effective in reflecting the radiant heat from the roof as Jon said. If choosing between fiberglass and bubble wrap, fiberglass is more effective (has a better R-value) for the same thickness, because the individual air spaces are smaller. Another option is closed cell foam, either foil lined or unlined. For sound insulation, heavier is better, and not in contact with either the inside or outside surface. That's why leaded blankets are sometimes use in high noise situations. The sound waves have a harder time moving the heavier blanket, when something lighter gets vibrated by the sound and becomes a speaker in effect.
This concludes today's lesson in heat transfer and sound transmission engineering. wink
Consider me a student. Glad I asked guys. I like the idea of placing the insulation on the underside of the headliner and such.
Moderated by  ndkid275, Phak1
