1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#1455269 06/15/2022 9:57 PM
I have a 57 Borg Warner 3 speed with overdrive. There is a clickity clack noise in first and second, and especially noticable at low speeds. I know it's the trans because it goes away when I press in the clutch. Is anyone familiar with this noise from the 3 speed? Thanks.
1958 Chevy Grumman Olson step van
I wanted to add that it only does it when I give it gas.
3B Offline
Hy Chaz 58, Check all your "U" joints for wear as well.
Chaz58 Sounds like you'll have to take it out and remove the side cover look in there for chipped gears. It's not rocket science but there is a lot of rollers and washers and entrails to fall out,have your service book handy. Now that's not so bad on just the sidecover just gotta hit the drum and low reverse slider to put it back on. Input shaft is full of rollers,hold them in place with grease,not bad to put it in the freezer in hot weather till you can "stab" it. As kids we soon learned the "tricks" !!
