| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I have a 57 Borg Warner 3 speed with overdrive. There is a clickity clack noise in first and second, and especially noticable at low speeds. I know it's the trans because it goes away when I press in the clutch. Is anyone familiar with this noise from the 3 speed? Thanks.
1958 Chevy Grumman Olson step van
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I wanted to add that it only does it when I give it gas.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chaz 58, Check all your "U" joints for wear as well. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chaz58 Sounds like you'll have to take it out and remove the side cover look in there for chipped gears. It's not rocket science but there is a lot of rollers and washers and entrails to fall out,have your service book handy. Now that's not so bad on just the sidecover just gotta hit the drum and low reverse slider to put it back on. Input shaft is full of rollers,hold them in place with grease,not bad to put it in the freezer in hot weather till you can "stab" it. As kids we soon learned the "tricks" !! | | |
