1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Does the 1950 Chevy 1/2 T have a fuse panel? If so where located? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The text says 50-51 had only 2 fuses as seen in diagram provided by Tim. Whereas the 48-49 had 5 fuses. This corresponds to a change from a 48-49 30A light switch breaker to a 42A for 50-51. Automotive electrical was still evolving. Still a lot of goofy ideas up to the 1963 and 68 model year.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | I noticed this the other day in the shop manual. Curious why the number of fuses went backwards.
1951 3100
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | ....and in 55.2 it changed again. Two 13A light switch breakers and no fuses. As in all industries, lessons were learned, philosophy changed, consumers wanted safety and reliability.... and colleges were offering more specific degrees. Headlights have gone from bulbs to sealed beam and back to bulbs. Have you ever had to polish a sealed beam headlight to get the haze off?...............NO. Is a sealed beam bright enough? YES. I do get the reason for the modern bulb system. All kinds of nice looking styling can be had. Any lens shape a designer wants. I'm getting off topic now.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | My '50 has just two - Stop light and tail light.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The change-over from 5 fuses to 2 fuses might not have happened exactly on the change of the calendar/model year.
Supposedly, the assembly plants changed to a new part as soon as the old part ran out.
So, 1950 and 1951 would be the transition model-years for these types of fuses. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes Otto, that is what the text and diagram say for 50. Two fuses.
Agreed Tim, I was just mentioning what the text and diagram says. Lot's of transition anomalies thruout the years.
To all and me: The last six posts are all repetitive. Dead horse style.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Yes Otto, that is what the text and diagram say for 50. Two fuses.
. Sort of. The Classic Parts Listing says 1947-1950 uses the 5 fuse box, which is confused me when I opened mine up.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The online manual by GM and the GM heritage Center Specification book say the same thing. 1950... two fuses, one spare, mounted on "front of dash". Stop and Tail. 20A glass cartridge. (kind of a big amp sizing for tail lights) That is the only documentation from GM I know of. Does not matter what a vendor says or if there were extra parts overlap. The correct set up is documented. It's possible that dealers or up fitters added fuses when heaters, spotlights and radios were added....and of course PO's. If a guy, who owns a 50, buys a 5 fuse holder from a vender who advertises it as correct, from then on it's deemed correct. That's how it goes sometimes. Doesn't matter.
Any fuse box can be used on any truck. When purity is not the goal.
