4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#1453444 05/31/2022 8:12 PM
Hi All,
Truck is about done but needs aligned this week. Its a 1938 1.5 ton, so may require a machine bending the ibeam in the front because its positive camber right now. We're getn the run-around from one shop that said they could do it and now says they cant... Any shops in maryland that are any good?
also - the new rear axle is slightly thinner than the cast brackets that hold around it.. it slipped on the test run arrgggg; need a shop that can help with both ! :/
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Any heavy duty truck repair can handle that. Most are I-beam front axles.
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Have you tried Peters Springs in Baltimore?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The only thing a shop needs to correct camber on a straight axle is a piece of heavy I beam, a big chain, and a 20 ton bottle jack. What's lacking is experience and a willingness to do a little manual labor. A little bit of positive camber is a good thing, as long as both sides are equal. Tires roll toward the way the top of the wheel is pointed, so positive camber makes the vehicle roll toward the centerline or the curb, depending on which wheel is involved. Equal positive camber on both sides makes a vehicle on a level road run straight ahead.
Thanks guys; weird, I tried Peter Springs. Two weeks a go the guy said they can do it, no problem.. today they said they cant! eek
Can't do it because he's busy or short handed...or just can't do it because it's old iron??? Drive the truck over and show him how easy the job is...
You could call R & S in Bladensburg and see if they can do it...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks. They said they could do our trucks two weeks ago. Today some other dude picked up the phone and said they dont do “38’s. I dont get it. Bladensburg is too far unfortunately. I need something closer to pa or baltimore (north).
Call Moxley's in Street, MD and see who they recommend, they're in the truck body/fabrication business...good people to know!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Riding in the Passing Lane
That rear axle is supposed to turn inside the clamps. The torque tube supports it from turning too far. There should be a grease fitting on the clamp to keep it lubricated.
George
1972 Chevy c10 Cheyenne Super
this is a dana 60 axle
" the new rear axle is slightly thinner than the cast brackets that hold around it.. "
I think we will end up having to weld the new axle in in order to keep the old clamps and springs.
Don't rely on clamps to keep the axle housing from turning. Shim the clamps with a piece of steel plate to get the radius right, set the pinion angle where it needs to be, and then drill and tap the top of the bracket and the axle tube for a bolt- - -maybe 3/8" or 7/16" in diameter. The bolt will keep the housing from turning due to torque on the axle tubes.
Crusing in the Passing Lane
If one measures the axle shaft OD, measures the housing ID, divides the difference by two, one gets the spacer thickness required. Search for a handy piece of scrap, the OD of which matches the axle, cut the spacer the correct dimensions and center it in the housing, insert the scrap, use the scrap piece to push the spacer into the housing in a press, repeat for other half.
I put a D-80 in GMC 370 that way.
Ed
Thanks for all of your input guys.
Moxley's can do welding fab. I am going to work with a local mechanic to put a king pin in, he said that is the issue with the camber. I will report back!
