1 members (Otto Skorzeny),
85
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 36 | I had my brake shoes and clutch plate relined and disk resurfaced on my 50 GMC 1 ton. Great people to work with at City brake and clutch in Oklahoma City if you need this service this is the place.Their phone is 405-235-1164. | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 |
Professional Novice
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | forman Used to do my own brakes but hard to find rivets and lining. Have a foot operated outfit goes on the wall,can put the hammer on those rivets with it. Very important to not let the lining pucker between rivets. Also can arc the shoes but seems wasteful when you see the dust fog off of the grinder,of course the bigger the drum the worse it is !! | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | I believe that the brake shoes should be arched before the lining is installed. You can check the arch by placing them inside the drum and look at how close they fit. The shoe can then be adjusted before the lining is installed.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
