7 members (crenwelge, DadsFirstPickup, Hotrod Lincoln, Peggy M, Otto Skorzeny, 2 invisible), 99 guests, and 3 robots.
Topics128,127
Posts1,056,675
Members48,450
#1453139 05/28/2022 3:24 PM
Can I use a 8.25x15 tire on a rim that has a 8.25x20 tire on it?
Found the 15's cheaper and seeing if its comparable
H Online: Content
Since the last number in the sequence is the rim diameter in inches- - - - -NO! The hole in the middle of the tire would be 5" too small! Good luck getting it to stretch over a 20" diameter rim!
Thanks still new in this department and with 2 numbers to go with on tire size wasnt sure if it was inches or something else
O Online: Content
8.25 = section width = width of tire mounted on wheel (may be slightly wider than tread width)
15 = rim diameter in inches
My tires 215 / 70 x 16
215mm = section width
70 = aspect ratio = height of sidewall from ground to rim = 70% of section width = 150.5 mm
16 = rim diameter in inches
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Otto, I've encountered a few tires labeled with the rim diameter in millimeters- - - - -now, that can really get confusing!
O Online: Content
No doubt!
Luckily once I find a size that works on a particular vehicle, I never change.
