| | | Forums66 Topics128,128 Posts1,056,664 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 21 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 21 | Can I use a 8.25x15 tire on a rim that has a 8.25x20 tire on it? Found the 15's cheaper and seeing if its comparable | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Since the last number in the sequence is the rim diameter in inches- - - - -NO! The hole in the middle of the tire would be 5" too small! Good luck getting it to stretch over a 20" diameter rim! Jerry
| | | | | Joined: Nov 2020 Posts: 21 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 21 | Thanks still new in this department and with 2 numbers to go with on tire size wasnt sure if it was inches or something else | | | | | Joined: Oct 2021 Posts: 6,902 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,902 | 8.25 = section width = width of tire mounted on wheel (may be slightly wider than tread width) 15 = rim diameter in inches
My tires 215 / 70 x 16
215mm = section width 70 = aspect ratio = height of sidewall from ground to rim = 70% of section width = 150.5 mm 16 = rim diameter in inches
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Otto, I've encountered a few tires labeled with the rim diameter in millimeters- - - - -now, that can really get confusing! Jerry
| | | | | Joined: Oct 2021 Posts: 6,902 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,902 | No doubt!
Luckily once I find a size that works on a particular vehicle, I never change.
