3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
My brother bought this truck from California last week. Can someone more skilled than me decipher the serial number? BHCA938475
I’m afraid it might be a California applied number. Supposed to be a 1950 maybe a Suburban or Panel, it’s had some work done on the body.
I looked at the GM Heritage site and the "B" and "C" don't work as well as the 938475 for a production number. I suspect your suspicions may be correct regarding the California issue. Just to verify, these are stamped on the vehicle identification plate on the drivers door pillar, correct?
Ron - - Dusty53
1954 Chevy 3604
Negative. No door post plates only numbers on a title. Sorry, I should have mentioned that.
Ex Hall Monitor
Ex Hall Monitor
Looks like the engine number of an engine built in Flint RPO227: http://chevy.oldcarmanualproject.com/chevyresto/5052.htm
Ah-ha! Good find, Tiny !
Martin, can you have your brother check the Engine stamp and see if it matches what's on the title?
Ron - - Dusty53
1954 Chevy 3604
It does match.
Ex Hall Monitor
Ex Hall Monitor
That's the first place I look for a pre 55 Chevy VIN. chug secret
A California Assigned DMV Number would be a blue/silver plate that is pop riveted on either the firewall or the door jam.
It would have a Letter/Number sequence like: DMV12345CA
Usually installed when the Serial/VIN number is missing or damaged.
Fred
Thanks, that eliminates the California theory.
