7 members (Gdads51, Cletus1950, cmayna, 55shaker, 3800GUY, Gray_Ghost, FAST55), 145 guests, and 0 robots.
Topics128,109
Posts1,056,253
Members48,437
#1452767 05/25/2022 9:37 PM
i have the engine sitting on the forward motor mounts. the rear is on a couple of blocks about an inch thick. i don't have the rear mounts yet.
the engine in that position is about 10-15 degrees rear low. that seems a bit too much, and i doubt that the rear mounts when i get them in will change it much or even make it worse.
what should the attitude of the engine be if not level?
1963 c10
rgie #1452771 05/25/2022 10:26 PM
Sir Searchalot
Sir Searchalot
Generally you level the carb. The motor is built to give a 4 deg down. (crank shaft/bell housing) This is to facilitate a good pinion angle. It's good to try and install like that. There can be situations where you can deviate.
There is a lot about what you are doing that we don't understand. So just a general answer can be made.
rgie #1452774 05/25/2022 10:45 PM
Are you using the bellhousing with the rear mounts at about a 45 degree angle to the crossmember? Those mounts are pretty thick, which should establish the right angle for the crankshaft. The same cast iron bellhousing was used for both 6 cylinder and V8 truck engines in 63. The aluminum passenger car housing won't work without fabricating mounts for both the engine and transmission.
rgie #1452822 05/26/2022 10:39 AM
thanks guys.
yes the bell does have the 45 degree mounts.
it was in a 65 c10 when i got it.
the casting number is for a corvette.
thanks again.
rolf
1963 c10
