| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i have the engine sitting on the forward motor mounts. the rear is on a couple of blocks about an inch thick. i don't have the rear mounts yet. the engine in that position is about 10-15 degrees rear low. that seems a bit too much, and i doubt that the rear mounts when i get them in will change it much or even make it worse. what should the attitude of the engine be if not level?
1963 c10 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Generally you level the carb. The motor is built to give a 4 deg down. (crank shaft/bell housing) This is to facilitate a good pinion angle. It's good to try and install like that. There can be situations where you can deviate. There is a lot about what you are doing that we don't understand. So just a general answer can be made.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,802 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,802 | Are you using the bellhousing with the rear mounts at about a 45 degree angle to the crossmember? Those mounts are pretty thick, which should establish the right angle for the crankshaft. The same cast iron bellhousing was used for both 6 cylinder and V8 truck engines in 63. The aluminum passenger car housing won't work without fabricating mounts for both the engine and transmission. Jerry
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys. yes the bell does have the 45 degree mounts. it was in a 65 c10 when i got it. the casting number is for a corvette. thanks again.
rolf
1963 c10 | | |
