| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | My brother bought this truck from California last week. Can someone more skilled than me decipher the serial number? BHCA938475 I’m afraid it might be a California applied number. Supposed to be a 1950 maybe a Suburban or Panel, it’s had some work done on the body.
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | I looked at the GM Heritage site and the "B" and "C" don't work as well as the 938475 for a production number. I suspect your suspicions may be correct regarding the California issue. Just to verify, these are stamped on the vehicle identification plate on the drivers door pillar, correct?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Negative. No door post plates only numbers on a title. Sorry, I should have mentioned that.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Looks like the engine number of an engine built in Flint RPO227: http://chevy.oldcarmanualproject.com/chevyresto/5052.htm
| | | | | Joined: Jul 2014 Posts: 1,291 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,291 | Ah-ha! Good find, Tiny ! Martin, can you have your brother check the Engine stamp and see if it matches what's on the title?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ah-ha! Good find, Tiny !
Martin, can you have your brother check the Engine stamp and see if it matches what's on the title? That's the first place I look for a pre 55 Chevy VIN.
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | A California Assigned DMV Number would be a blue/silver plate that is pop riveted on either the firewall or the door jam. It would have a Letter/Number sequence like: DMV12345CA Usually installed when the Serial/VIN number is missing or damaged. Fred
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Thanks, that eliminates the California theory.
