| | | Forums66 Topics128,163 Posts1,057,072 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 2 Moderated | | Moderated Joined: May 2022 Posts: 2 | Good morning, this is my first posting on your site and firstly thank you for accepting my request.
My neighbor Barry has a 1954 Chevrolet farm truck with a Timken 2 speed diff and although its still working, is showing signs of age cracking on the diaphram. Its a Timken with the diaphram measuring 7 inches in diameter, a 3 inch hole in the center for the two pressed metal actuator plates and from the side a 1 inch step up for the in/out movement. To this point l have been tasked with locating a new replacement, with little to no success.
Anyone here knw where l can direct Barry to for his purchase?
Thanks in advance for your assistance.
Cheers David Dare Victoria Australia
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy DAVE_AUSTRALIA, welcome, the original part number for the diaphragm was 3847058 maybe a search of Ebay might turn one up, good luck. | | | | | Joined: Feb 2016 Posts: 148 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 148 |
-David
1953 2-Ton GMC
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Dave australia Chapman Chevrolet in Tempe Arizona carries that 3847058 diaphragm . | | | | | Joined: May 2022 Posts: 2 Moderated | | Moderated Joined: May 2022 Posts: 2 | A big shout out to those above for your assistance, 3B,David Braley & fixite7. I will be ordering that part either ebay or chev dealer (if they respond). Cheers again David way down under in Aus. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Dave Australia Glad to help,shifted mine several times today...big fun when she shifts !! | | |
