| | | Forums66 Topics128,128 Posts1,056,668 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 15 | My new to me 1946 2-ton needs one set of rear brake shoes. A local and reputable shop has had the shoes for almost 4 weeks now while waiting for the shoe material to show up. Does anyone know where to go to get them relined? Thanks in advance.
1946 2 ton
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Clutch exchange in Denver, CO, although there might be a closer place!
Ed
| | | | | Joined: Apr 2022 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 15 | Thanks for the tip Ed. Unfortunately when I tried to call Clutch Exchange their phone was disconnected.
1946 2 ton
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I haven’t been there since Covid struck, sorry.
Ed
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | San Antonio Brake & Clutch in San Antonio, TX used to carry a lot of stuff. You might give them a call. (210) 226-0254 However, they may be like so many businesses. The old timers retire and the younger generation just doesn't care. | | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | I have rear linings. PM me, call me at 573 864 6539 or direct email at [email protected]Mike Russell Missouri | | | | | Joined: Nov 2009 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 123 | On my Chevrolet 56 6100 I sent all my shoes (including the parking brake shoes) to Brake Materials and Parts in Fort Wayne IN. Paid about $400 for all 10 shoes, including shipping both ways. They did a great job, came back repainted and relined, they look brand new | | | | | Joined: Apr 2022 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 15 | Awesome, thanks for the options.
1946 2 ton
| | | | | Joined: May 2009 Posts: 135 'Bolter | | 'Bolter Joined: May 2009 Posts: 135 | Dana, I got your check today. Thanks. Did I miss a call yesterday? do you need another lining? I checked I and have some odds and ends. My phone does not tell me when I have missed a call. I missed one from Swansea. You?
Mike
| | | | | Joined: Apr 2022 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 15 | Hi Mike, No I did not try to call you today. I had the linings you sent me installed on the shoes by a local shop. Everything is back on the truck working fine. I only needed enough lining to do one side which was soaked with brake fluid. I just put the other set with the cracked lining on a shelf hoping I won't need it. I suppose if you have an extra lining kicking around I should grab it cause you never know.
1946 2 ton
