0 members (), 66 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#14508 07/26/2003 8:50 PM
Pal
Offline
Ok Guys,
I'm trying to get my 68 p/u to run correctly. Timing is 4 btc, Idle 680. Electronic ignition. (oh yeah, 250 CID with 1 brl, 4spd manual). Plenty of power, mileage 11mpg (yuk).
So why does she diesel when I shut her down? No leak at manifold, or Carb. I've tried to advance the timing, to 6 and 8 btc, engine runs smoother, still diesels.
35 + years of rollin' steel!
#14509 07/26/2003 9:15 PM
Your poor fuel economy may be a clue. Dieseling is sometimes caused by fuel draining out of the carb after shutdown. When the engine is hot it doesn't need spark to ignite fuel that dribbled into the combustion chambers. Does the throttle plate close completely when you shut it down? Is the choke functioning correctly?
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#14510 07/26/2003 11:02 PM
Pal
Offline
Good point Hedgehog. I'll check into the carb. I know I've cleaned the outside to a purdy shine (ok, less dingy) and the linkage seem to be smooth. Choke is disconnected at the moment and open since I need a new cable. In this heat I don't need it much.
#14511 07/27/2003 11:07 AM
Try turning down you idle speed as low as it will run, maybe 450 rpm.
#14512 07/27/2003 3:40 PM
The problem is the "stuf" they sell as gasoline today. Try a higher grade of fuel.
if it dosen't need fixed, break it
#14513 07/27/2003 10:01 PM
I had a '70 Buick Skylark conv. with the 350 in it. It also did that running on thing , I traced it to the throttle not closing off properly when the eng. was shut down.
On that engine there was a device (vaccuum or electric, I dont remember) that pulled the throttle properly closed when the eng was shutoff , it was faulty.
Temporary fix was to adjust the idle setting .
#14514 07/30/2003 6:59 PM
Another thing that can cause run on is carbon build up on the tops of the pistons, and engine temp.
#14515 07/30/2003 10:20 PM
I bet your power valve in the carb is stuck open. That will dribble in extra fuel and give you terrible economy but won't affect power.
Paint & Body Shop moderator
