7 members (GusG, J Lucas, TexasJim50, Peggy M, Gdads51, Southerntruck, klhansen), 113 guests, and 2 robots.
Topics128,089
Posts1,056,422
Members48,443
#1449835 04/29/2022 1:00 AM
I've had this stashed for years, got it from a 65 w/ 292. Questions 1: will it work on HEI system.
#2, wiring, is this correct: from rear view, l.h. stud pink wire: switched ign 12v, r.h. - brown tach input from coil.
Thanks for the input.
BC
1960 C60 pasture art
Moderator, Electrical Bay
I expect it will work on an HEI system. Are you using aftermarket or GM HEI?
~ Jon
HEI, just like the Trans, S10 parts.
BC
There were usually only 2 connections on the S10 HEI (at least the one I owned)...as I recall one was red and one was green. Green fed impulses to the tach. I expect the green wire would connect to your brown wire and your pink wire would be + from ignition. Ground would be the instrument cluster although I can't tell what that other wire is in your image up there. Good luck.
~ Jon
Center wire is illumination bulb.
BC
Yes, I know that. There appear to be 4 wires up there and I can't see what the other is or if it splices into the brown wire...
~ Jon
An illusion, 1 wire tucked under itself.
BC
It works!
BC
Fantastic! Neat tach and I like your Fluke meter.
~ Jon
I've seen repo ones but only for 8 cyl.
I have another older one with a transmitter box but haven't been able to make it work.
BC
You can see I fit a very small one into an AD speedometer I was modifying (along with a small vacuum gauge) here:
https://www.stovebolt.com/ubbthread...52-gauge-decal-template.html#Post1398550
Look at the image to the right...
~ Jon
Nice job, Jon!
Meter is an older Fluke 88, bought it new (early '90s), it's nice to have all my tools at home now since I retired from the g.m. dealer life.
BC
Thanks! Soon...maybe in another month I'm going to be making a GPS speedometer for the AD truck. One that will be pretty much "plug and play" for folks using a T5 transmission, different rear end, maybe different diameter tires.
Retirement is nice, isn't it? Makes me wish I could have lived like Travis McGee in the John D. MacDonald novels. Now that you're retired, you might enjoy reading those. "The Deep Blue Goodbye" is the first one...
~ Jon
