0 members (), 133 guests, and 4 robots.
Topics128,186
Posts1,057,211
Members48,465
Junior Member
Junior Member
I need some experenced help in finding out how to time this engine and set the valves.
I have not been able to find the specks at this time.
Here is what's going on at this point. The motor idles good, I Have no problem starting up but when engine speed increases the engine is popping through the carb and showing a loss of power.
I notice the Distributer is wabbling when the enging is running what's next? Motor replacement.
I have located a 6 cylinder chevy engine in a 1975 1/2 ton truck will the engine bolt up to the original trany? I'm not sure what size it is but could it be a 250?
Any Idea on what would work for a motor swap?
Thanks for any help keeping the truck out scrap yard!
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
When you hit the throttle, a vaccume line twists the distributer to advance the timing.
If it idles fine, i'd guess the timing is set fine.. maybe you have a vac leak that keeps it from twisting the distributer enough?
I'd have a buddy give it a little gas till it starts popping, then you twist the distributer counter clockwise, and if the popping stops, then thats whats going on.
Check this out thats a 40's shop manual, but the information on timing and such will be the same for a '50 235.
Riding in the Passing Lane
If the dist. is wabling the shaft is bent. That could cause the popping back trough the carb. Get another dist. & set the points & timing. The timing is set by a timing light shineing on a hole in the bell housing above the starter. Line the shiny ball up with the pointer in the center of the hole. If it still pops you may have a valve adjusted too tight or a worn camshaft.
1972 Chevy c10 Cheyenne Super
I agree with Wrenchbender, your distributer is N.F.G.. Start there and it should clear up.
Junior Member
Junior Member
I did not find a ball on the flywheel so I ended up turning the Distributer until the back firing thru the Carb stopped.
I discovered Some local No Dak Farmer put this motor in this truck years ago. I don't think they used the original flywheel. I could not see any marking when I was timing it. Today's temp was 8 degress in the driveway with out the wind chill. I set the valves and adjusted the timing, so far the rattling noise has stopped but it still has that knock in the bottom end. HUM- Will Slick 50 quite down the noise? You cant here the clunk when the motor is reved up! Is it serious???
