When you hit the throttle, a vaccume line twists the distributer to advance the timing.
If it idles fine, i'd guess the timing is set fine.. maybe you have a vac leak that keeps it from twisting the distributer enough?
I'd have a buddy give it a little gas till it starts popping, then you twist the distributer counter clockwise, and if the popping stops, then thats whats going on.
Check this out thats a 40's shop manual, but the information on timing and such will be the same for a '50 235.
