4 members (Fannin, 2-Ton, Phak1, TUTS 59), 170 guests, and 3 robots.
Topics128,084
Posts1,056,085
Members48,434
I have a 1948 3100 original truck. The speedometer recently started making a screeching noise so I unhooked the speedo cable and used white lithium grease to lube the cable. When I hooked it back up, the speedometer started moving up to about 10-15 mph then dropped back down and never moved again. The odometer is working fine so I'm assuming its not a cable problem but a speedometer gear problem? Do I need to replace the whole unit or can I replace the gears? or is there another fix to try? Thanks so much!
Moderator, Electrical Bay
Somewhere at sometime I posted information on how to clean and oil the AD speedometer head and I've posted under separate headings how to use the waterslide decal templates I have provided to renew the numerals (and set those to any mileage needed in case you have to replace one). There will be a post also on how to repair a broken speedometer shaft (very common if somebody isn't careful removing the needle). Just a few weeks ago I sold one I had rebuilt. I think these posts were all in the "Interiors" section. Your speedometer may be suffering a few different problems but my first guess is that it is sticking and needs cleaning and lubrication.
~ Jon
Here is the odometer renewal post: https://tinyurl.com/2p99h5yk
~ Jon
This one may be helpful: https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1399501/1.html
There's another somewhere. Wish we could add to Tech Tips.
~ Jon
Thank you Jon !!
