7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 9 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 9 | I have a 1948 3100 original truck. The speedometer recently started making a screeching noise so I unhooked the speedo cable and used white lithium grease to lube the cable. When I hooked it back up, the speedometer started moving up to about 10-15 mph then dropped back down and never moved again. The odometer is working fine so I'm assuming its not a cable problem but a speedometer gear problem? Do I need to replace the whole unit or can I replace the gears? or is there another fix to try? Thanks so much! | | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | Somewhere at sometime I posted information on how to clean and oil the AD speedometer head and I've posted under separate headings how to use the waterslide decal templates I have provided to renew the numerals (and set those to any mileage needed in case you have to replace one). There will be a post also on how to repair a broken speedometer shaft (very common if somebody isn't careful removing the needle). Just a few weeks ago I sold one I had rebuilt. I think these posts were all in the "Interiors" section. Your speedometer may be suffering a few different problems but my first guess is that it is sticking and needs cleaning and lubrication.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,485 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,485 | Here is the odometer renewal post: https://tinyurl.com/2p99h5yk
| | | | | Joined: Jul 2014 Posts: 9 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 9 | | | |
