6 members (Gdads51, GMCJammer51, NJC, Southerntruck, John L., 3B), 123 guests, and 3 robots.
Topics128,091
Posts1,056,392
Members48,442
I hope this is the most correct forum for this question. What are the differences between the standard and deluxe heaters for the Advance Design trucks?
This might help.
The standard recirculating type heater does just what the name implies. It only reheats the air inside the cab by recirculating it around in a closed circuit. The deluxe “fresh air” heater connects to the outside air by being bolted to the kick plate over the louvred side vent. It pulls in outside fresh air to be heated. I believe a later fresh air model had a door that could be closed shut via a cable that would block off the colder outside air. All 3 models have a lever that can divert the warmed air to defrost the windshield.
Those with more expertise in heaters will give more precise details.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
As far as my recent knowledge on the subject, that is pretty spot on.
I'm working on restoring a 'fresh air' setup. The big problem which could cross over to the recirculating model is the 'Ranco' heater thermostat. If you are looking for full restoration specs, that might be a pricey brick wall. I'm opting for the Ranco t-stat placement for looks but putting in a mechanical on/off coolant shutoff valve to the core using the old 'T' throttle cable to control from the dash during cold/defrost days.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
