1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi all, Does anyone know where to get an electric fan and shroud for my 1938 (with 292ci) ? Same size rad as original.. 16x20 coverage .. Looking for a univeral maybe that wont be $$$$$$$$$
To add: A. The fan is on the outside of the rad, not on the engine side because of space. B. I dont know if that makes it a push or pull.. I think its a push though C. Do such fans NEED a shroud? A shroud would seem to block air.. Does it create hot spots without a shroud? D. Any suggestions for cfm?
Thank guys.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | A pusher does not need a shroud. Get the largest aluminum 3-4 row radiator that will bolt in place and then the largest cfm pusher electric fan that will mount in front of it. Evilbay and a tape measure are your best friends. Good luck.
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | The best fans I've found are made by Spal (Italy). Not the least expensive but there's a big difference between precision fans made in Italy and what you get from China.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | If they won't give CFM rating, look else where. Get the highest CFM you can and don't use a full shroud. There needs to be room for air to get through the core when out on the road. At highway speeds you could turn the fan off and likely still cool the engine just fine. With a full shroud, that won't happen! You may have room on the sides for the fan to hang over, this will allow even bigger diameter and more CFM. | | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | I just bought a pusher fan from jegs.com that was cheap and has 2300 cfm I think for my 51 with 261 in it. Depends if you want a slim one or not.
Chris | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | I saw this a month or two ago and thought it was interesting: https://www.lsxmag.com/features/pri-coverage/pri-2021-spal-explains-why-brushless-fans-rule/Auto fans can be brushed or brushless. Brushless in my opinion is better. Over the last 40 years, I've dissected probably 40 brushless fans to determine why they fail and about 20 brushed fans for the same reason. If anyone here wants that information, I'm happy to share. Just let me know.
