1 members (Bill Hanlon), 167 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,471
Hi all,
Does anyone know where to get an electric fan and shroud for my 1938 (with 292ci) ? Same size rad as original.. 16x20 coverage .. Looking for a univeral maybe that wont be $$$$$$$$$
To add:
A. The fan is on the outside of the rad, not on the engine side because of space.
B. I dont know if that makes it a push or pull.. I think its a push though
C. Do such fans NEED a shroud? A shroud would seem to block air.. Does it create hot spots without a shroud?
D. Any suggestions for cfm?
Thank guys.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
A pusher does not need a shroud. Get the largest aluminum 3-4 row radiator that will bolt in place and then the largest cfm pusher electric fan that will mount in front of it. Evilbay and a tape measure are your best friends. Good luck.
Moderator, Electrical Bay
The best fans I've found are made by Spal (Italy). Not the least expensive but there's a big difference between precision fans made in Italy and what you get from China.
~ Jon
If they won't give CFM rating, look else where. Get the highest CFM you can and don't use a full shroud. There needs to be room for air to get through the core when out on the road. At highway speeds you could turn the fan off and likely still cool the engine just fine. With a full shroud, that won't happen! You may have room on the sides for the fan to hang over, this will allow even bigger diameter and more CFM.
I just bought a pusher fan from jegs.com that was cheap and has 2300 cfm I think for my 51 with 261 in it. Depends if you want a slim one or not.
Chris
I saw this a month or two ago and thought it was interesting: https://www.lsxmag.com/features/pri-coverage/pri-2021-spal-explains-why-brushless-fans-rule/
Auto fans can be brushed or brushless. Brushless in my opinion is better. Over the last 40 years, I've dissected probably 40 brushless fans to determine why they fail and about 20 brushed fans for the same reason. If anyone here wants that information, I'm happy to share. Just let me know.
~ Jon
