1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 30 Apprentice | | Apprentice Joined: Jul 2005 Posts: 30 | looking for input on the subject of just replacing my points or upgrading my distributor with an electronic upgrade kit or a whole new distibutor setup?
Pro's and cons please?
Thanks Matt | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | if you are starting the truck regularly a regular tune-up will proably be fine. With my 38 I found that a scavanged electronic distributor from a 81 chevy did the trick. Same trick did not work for the 54 though the distributor shaft wouldn't engage the oil pump. | | | | | Joined: Nov 2004 Posts: 2,400 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,400 | What are you trying to accomplish? Unless you are going to change more than just the distributor, I don't think that you will gain a whole lot. If it has good vitals (compression and oil pressure) and you just want a dependable driver, I say go with new points, cap, rotor, plugs, etc. It should run great, and will not cost you much. If you want to go the high performance route, the distributor is just one component. You would also want improved carburation, intake and exhaust manifolds, and possibly at least a mild race cam, to reap a big gain. It is all based on what you really want.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2005 Posts: 30 Apprentice | | Apprentice Joined: Jul 2005 Posts: 30 | I was leaning towards just cleaning and or replacing the points, the electronic might be nice but you are right headers intake etc etc etc would add to that package, but that is not my goal for this truck right now I just need a dependable runner that runs drives & dumps. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You didn,t say what engine you have. If a electronic ign. conversion kit is available it is a good way to go. Other wise just make shure everything is in good condition. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 30 Apprentice | | Apprentice Joined: Jul 2005 Posts: 30 | I m sorry its a 327 with a 2 barrel | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Magilla88, could you tell us what year the truck is. The simplest thing to due would be installing a G.M. H.E.I. distributor common to G.m. since 1975 only problem might be firewall clearance the H.E.I. cap is much larger than the point type distributor cap. | | | | | Joined: Jun 2005 Posts: 35 Member | | Member Joined: Jun 2005 Posts: 35 | Go with the electronic ignition conversion/upgrade. I did because I'd much rather drive a vehicle than tinker with the points constantly. | | | | | Joined: Jul 2005 Posts: 30 Apprentice | | Apprentice Joined: Jul 2005 Posts: 30 | sorry its a 1963 chevy c50 w/ 327 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There should,t be any clearance problems on that model. Like 3B said the original equip. HEI is the best way to go. Crane has a conversion kit that is real neat & simple. I like it better than Petronics on that model dist. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 30 Apprentice | | Apprentice Joined: Jul 2005 Posts: 30 | ok that it sounds like thats the way to go (HEI) I will check it out, I may stay with points for a little while until I get all all the gremlins worked out of this old dog, but i am definiteley going to switch it over one less thing to fuss with.
I appreciate all the input. | | |
