1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
Apprentice
Apprentice
looking for input on the subject of just replacing my points or upgrading my distributor with an electronic upgrade kit or a whole new distibutor setup?
Pro's and cons please?
Matt
if you are starting the truck regularly a regular tune-up will proably be fine. With my 38 I found that a scavanged electronic distributor from a 81 chevy did the trick. Same trick did not work for the 54 though the distributor shaft wouldn't engage the oil pump.
Former Workshop Owner
What are you trying to accomplish? Unless you are going to change more than just the distributor, I don't think that you will gain a whole lot. If it has good vitals (compression and oil pressure) and you just want a dependable driver, I say go with new points, cap, rotor, plugs, etc. It should run great, and will not cost you much.
If you want to go the high performance route, the distributor is just one component. You would also want improved carburation, intake and exhaust manifolds, and possibly at least a mild race cam, to reap a big gain.
It is all based on what you really want.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Apprentice
Apprentice
I was leaning towards just cleaning and or replacing the points, the electronic might be nice but you are right headers intake etc etc etc would add to that package, but that is not my goal for this truck right now I just need a dependable runner that runs drives & dumps.
Riding in the Passing Lane
You didn,t say what engine you have. If a electronic ign. conversion kit is available it is a good way to go. Other wise just make shure everything is in good condition.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
I m sorry its a 327 with a 2 barrel
3B Offline
Hy Magilla88, could you tell us what year the truck is. The simplest thing to due would be installing a G.M. H.E.I. distributor common to G.m. since 1975 only problem might be firewall clearance the H.E.I. cap is much larger than the point type distributor cap.
Go with the electronic ignition conversion/upgrade. I did because I'd much rather drive a vehicle than tinker with the points constantly.
Apprentice
Apprentice
sorry its a 1963 chevy c50 w/ 327
There should,t be any clearance problems on that model. Like 3B said the original equip. HEI is the best way to go. Crane has a conversion kit that is real neat & simple. I like it better than Petronics on that model dist.
Apprentice
Apprentice
ok that it sounds like thats the way to go (HEI) I will check it out, I may stay with points for a little while until I get all all the gremlins worked out of this old dog, but i am definiteley going to switch it over one less thing to fuss with.
I appreciate all the input.
