3 members (baldeagle, NorCal52Suburban, DaveV), 124 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#144849 11/17/2005 4:08 AM
Junior Member
Junior Member
Hi, guys:
Newbie here. Recently acquired a 53 Chevy 6100 Ashton Wrecker. Am curious if there are power steering conversions available for this rig? Or if not, is there any other (newer) year truck or vehicle that may be a bolt on replacement? Don't laugh but I am not strong enough to drive this puppy in current standing. Am just a girl.
K. Wells
57Heaven
PS... Why the big rig? She was just too cute to pass up.
#144850 11/17/2005 6:35 PM
No PS available that I've heard of but many change the front end clips to something with a newer suspension and PS or or rack & pinion steering.
Start eating Wheaties and doing pushups, (<:
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#144851 11/18/2005 12:01 AM
ooops! ....duh! For some reason I was thinking I was still in the little bolts section. Probably why you double posted, huh?
El pardone.
Dave
#144852 11/18/2005 12:08 AM
Junior Member
Junior Member
Yep, sorry about that double post.. must plead insanity. First time for doing this and guess I hit the button twice when I didn't see it come up the first time... figured if a little is good.. alot must be better...LOL
#144853 11/18/2005 5:58 AM
The kingpin bearings may be worn out. Try jacking it up and see if it still turns hard. Power Steering is great, but you should be able to turn it pretty easy with the original set-up.
#144854 11/18/2005 8:26 AM
It might be worth looking into the vpower steering set up from a mid 70's C-60. I know you'd have to cut your steering column at the bottom and fit a bearing,and build a coupling from your steering shaft to the rag joint on the steering box,and I'm not sure what else would be involved,but it might be worth checking out. I used this steering box and P/S ram set up on my '66 C-60,and it was pretty much a bolt on installation,outside of building a bracket to mount the power steering ram to the middle of the axle. I do know on your truck the steering box and column are one piece,so that would have to be modified. I'm not sure if the steering box would bolt on or if you'd have to modify something to make it fit the frame. you might have to modify the link from the steering arm to the spindle,but that shouldn't be too hard. you'd have to work up some brackets to mount your power steering pump,but there's brackets available through some parts suppliers for light duty pumps,and I'm sure they can be adapted for the bigger truck P/S pump.
Granted,it'd be quite a project,but then,anything on the big 'bolts ia a big project,and it'll be so cool when it's done.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#144855 11/20/2005 3:56 AM
Junior Member
Junior Member
Good point Don. We'll check that out before starting the PS conversion... Had forgotten all about the Kingpins wearing?
57Heaven
