2 members (Bill Hanlon, Gray_Ghost), 44 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#144794 11/12/2005 8:45 PM
Junior Member
Junior Member
I recently got a hold of a 1965 C-60 and it needs alot of work. Especially brakes and clutch.
Any ideas? :confused:
#144795 11/12/2005 11:03 PM
redneck,
Yeah, get off the computer and get busy on the truck! grin grin grin
Stuart
#144796 11/12/2005 11:16 PM
Riding in the Passing Lane
It all depends on what you can do yourself. Thats some HD stuff. It depends on what you want to do with it. If you start takeing it to shops to have work done you will probably run into a nightmare. If you made a fantastic buy on it you might turn it for a quick profit.
1972 Chevy c10 Cheyenne Super
#144797 11/13/2005 9:50 AM
The clutch would be kind of rough unless you have a good flat concrete driveway or pad to work on. You might need to rent a transmission jack for a couple of days.Once the tranny is out,the rest of the job is much the same as it would be on a car. I believe you'll have to block up the rear of the engine and remove the bellhousing,that'll be six bolts into the block and 2 bigger bolts,the rear mounts.
On the brakes,get the truck on stands,all four corners,and do one side at a time so you can compare if you aren't sure how something fits.You can probably have a diesel truck shop or a brake rebuilder reline your shoes;that may or may not be cheaper than replacing them. As much as I hate to spend the money,I prefer buying wheel cylinders and master cylinder to re-building them;that's a lot of weight to have depending on any less than professionally rebuilt hydraulic parts. In your case,there'll be 2 wheel cylinders per rear wheel. It's a good idea to replace the flex hoses,and take a really good look at all the hard lines;replace anything that sits in a moisture trap (i.e. a low spot where water or mud stands in the frame)or shows signs of more than light rust or corrosion. You'll want to measure the drums and decide from that and the finish whether to have them turned. (Unless they're really chewed up,they'll probably be okay.) You'll probably not have to do anything to the booster,not much goes wrong with them.
This work is all do-able for most people if they have access to a transmission jack and a brake rebuilder. Main thing is to be safe and don't try to rush the job. I'm sure more 'bolters will have more info to help you.
Have fun!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#144798 11/13/2005 2:06 PM
easier to put a pipe from dash to seat and lower the trans with a come along from the inside.
Here is the site for my C-60 you might find something useable there.
http://home.earthlink.net/~64_chevy/
#144799 11/19/2005 4:54 PM
Junior Member
Junior Member
Thanks guys I do have access to many tools I just have little experience with something this old. The info you both gave me was great! Hope to get started on it soon it has been in the family for many years and I hope to put it into light duty service. Thanks again.
