0 members (),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 17 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 17 | How many gallons does the original tank hold? Not sure if it's the same as a '60-'62. | | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | BolognaBurrito, welcome to the Stovebolt. If you haven't already, feel free to go to the Welcome Forum and introduce yourself. Tell us a little about your project!
I'm not familiar with the early to mid sixties Suburban, but there are plenty of folk here who are. Someone will come along soon and give you an answer to your question.
Again, welcome to the Stoovebolt!! | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | According to the shop manual, 1965 Supplement ST-61, Specifications 11(page), Fuel Tank(section 8) : Cab Models: C L 10-60 M-60 K 10, K 20 Std. / 18.5 (Gallons) RPO NO.1 / 21.0 (Gallons) Panel and Carryall models: C 10, K10 / Std. / 20.5 (Gallons) C 30 / Std ./ 18.5 (Gallons) Guide to '60-'66 Chevy Truck Manuals - tech tip here on the bolt | | | | | Joined: Apr 2022 Posts: 17 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 17 | 18.5 gallons is what I'll keep in my head. Fuel gauge is broken and it's a bit far down on the list to fix.
Thanks! | | | | | Joined: Apr 2022 Posts: 17 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 17 | Welp, ran out of gas... luckily it happened as I was next in line at the pump, so the push was short. Only took 14.75 gallons to fill it up after that. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Now you know! Get that gas gauge working. Lots of good threads on it here.
| | | | | Joined: Feb 2015 Posts: 23 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 23 | My 64 C30 tank is 18.5 gallons, would like to get a second one for the passenger side.
Wylie johnson
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | I run mine down pretty far after the gauge hits "E" and i get 14 or so gallons in it. Always thought it was small, but maybe the othe 4 gallons are still in there? Lol. Or 14ish it is...  | | | | | Joined: Oct 2015 Posts: 406 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 406 | It seems the c 10 and c 20 panel with the filler door towards the rear has a larger tank , about 18 gallons where as the c 30 with the filler door just behind the drivers door has it seems only a 15 gallon tank . My 62 c 30 has the original tank and when the needle hits the E mark it quits . When at this point when I fill up I'm hard pressed to get a little better than 15 gallons US. when filling up right to the cap . I average just over 12 mpg a US. gallon and am comfortable running about 150 miles between fill ups. That being said on the long haul I generally carry a full jerry can although I haven't had to use it yet .
good planning is no substitute for dumb luck
