0 members (), 311 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Hello,
I am trying to find the correct Harrison Radiator for my 59 Chevrolet pickup. The ones that I picked up in a salvage may be correct, but I'm not sure.
# one:
Description and numbers: Harrison R60 59K 3145860, rubber overflow tube goes down metal channel made into radiator support.
90 degree mounting brackets with 6 holes on each side for mounting to core support.
# two
Harrison 11A B59 3135642. 45 degree bends in mounting bracket for mounting to radiator support. Radiator brackets are tapered so radiator sits at slight angle.
3 holes on each side for mounting. Overflow tube is metal with clips holding it to the radiator shell.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/images/57cmpc0177.jpg This is from the older parts manual. It lists the 3135642. We will have to wait for someone with a newer parts manual.
3135642 = 1955-59 Series 3 (2nd Series) w/ 2" core.
I believe B59 is the date code (Feb 1959).
I can't find any reference to the other radiator number...could it be out of a GMC???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The original radiator from my 59 has the numbers R11A, B 59 on one side, and 3135642 on the other side. I believe it to be the original radiator.
Mark
Mark, thank you for the kind reply. This should help me out a lot. 59Shortfleet
