1 members (2-Ton),
327
Mod | | | Forums66 Topics128,164 Posts1,057,076 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello,
I am trying to find the correct Harrison Radiator for my 59 Chevrolet pickup. The ones that I picked up in a salvage may be correct, but I'm not sure. # one: Description and numbers: Harrison R60 59K 3145860, rubber overflow tube goes down metal channel made into radiator support. 90 degree mounting brackets with 6 holes on each side for mounting to core support.
# two Harrison 11A B59 3135642. 45 degree bends in mounting bracket for mounting to radiator support. Radiator brackets are tapered so radiator sits at slight angle. 3 holes on each side for mounting. Overflow tube is metal with clips holding it to the radiator shell. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | 3135642 = 1955-59 Series 3 (2nd Series) w/ 2" core. I believe B59 is the date code (Feb 1959). I can't find any reference to the other radiator number...could it be out of a GMC??? Mike B  | | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | The original radiator from my 59 has the numbers R11A, B 59 on one side, and 3135642 on the other side. I believe it to be the original radiator.
Mark | | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Mark, thank you for the kind reply. This should help me out a lot. 59Shortfleet | | |
