2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#1446333 03/29/2022 2:21 AM
I was able to source a set of 3.55 R&P gears for my 46 1/2 ton. This thread is multi-purpose, and forgive me if it needs to go into the parts wanted forum.
For those that have done the R&P conversion, any and all advice, suggestions, do's and don'ts are greatly appreciated. Procedures, tool recommendations ect.
I have been following Deve's torque tube rebuild/overhaul article. It contains a very comprehensive parts list as far as installation parts are concerned.
www.devestechnet.com/home/DifferentialOverhaul
I have located the majority of parts from several different suppliers. I can not locate the differential side bearings (Hyatt #KA-11445-Z), the Front pinion bearing (New Departure #5306), and the Rear pinion bearing (Hyatt #OR1506/46B or C-1506). These manufacturers and part numbers are from the Deve's list. Does anyone know of anyone or anywhere I might be able to source them. Or, do you have alternative part manufacturers and numbers.
Appreciate everyones time and input.
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
bigedpa #1446364 03/29/2022 12:41 PM
If you current diff is in good working order…………….just replace the gears, all that’s needed is a shim selection. Bearing can all be reused with no problems.
YES…………I get the concept of as long as I am in there I will replace everything in sight……….but………..it might not need everything. Mine was fine reused all the bearings.
