4 members (TUTS 59, PAUL Berardi, wilbur53, 1 invisible), 112 guests, and 0 robots.
Topics128,132
Posts1,056,376
Members48,441
#1445483 03/22/2022 1:57 PM
What year would this chevy truck be? vin DBA554708 Looking to buy for grandson. No pictures but is a solid farm truck.
forman #1445487 03/22/2022 2:14 PM
Kansas Auctioneers Associations 4/18 auction lists that vin number with photos as a 1947 chevy lot #112.
1952 Chevy Pickup Truck
forman #1445493 03/22/2022 3:00 PM
Ex Hall Monitor
Ex Hall Monitor
forman #1445495 03/22/2022 3:32 PM
Your grandson would be the envy of all his buddies! No loader on site means a lot of hand digging and fancy Jack work. Good luck on your bid.
forman #1445498 03/22/2022 3:55 PM
It appears to have a later 235 engine in it. It could be worth looking into.
Fred
forman #1445500 03/22/2022 4:07 PM
The box sides are from a newer 55 and up truck ,newer motor ,looks good on top been sitting in the dirt for awhile hopefully not to corroded from the dirt . Yes you will need a few shovels jacks and some air for tires I see there are a few extras in the box .good luck let us know if you get the prize.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
forman #1445533 03/22/2022 9:24 PM
The sheet metal looks promising. Grille looks pretty darned good.
I cringe when I look at how that old iron is squatting in the dirt- I hope the underside corrosion isn’t too bad.
Very attractive body style, certainly worth looking into.
forman #1445534 03/22/2022 9:33 PM
FWIW, that area of Oklahoma, averages 31” of precip and 228 sunny days per year.
The precipitation is below National average, sunshine above average. If the soil is of loose , well drained composition there is hope.
forman #1445539 03/22/2022 10:39 PM
You will be bidding against Bud’s Antique Vehicle Salvage yard in Aline, Okla.
KEVINSKI #1445547 03/23/2022 12:01 AM
I think the whole bed is from a 55ish truck, including the tailgate with the Chevrolet stamping on it. The pre-AD trucks had a plain tailgate, and the bed was narrower as well.
Might be a good project, but the wheel & brake components are probably pretty rusty from being buried in the dirt. Hopefully not too bad.
forman #1445558 03/23/2022 2:36 AM
The serial number indicates it's a 1946, but it's missing the first number/s for plant identification...
DBA554708 here's the way I see it,
x = Assembly Plant (1 = Flint, 3 = St Louis, 5 = Kansas City, MO, etc.)
D = 1946 second design (C = 1946 first design, E = 1947)
B = this is a typo, could be P which is the 1/2 ton truck
A = Month (Jan)
554708 = Unit number
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
forman #1445569 03/23/2022 3:43 AM
She's definitely been sitting there a while, the way it's sunk into the dirt.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
forman #1445641 03/23/2022 7:24 PM
What about the horizontal ridges in the sides of the box? I am not familiar with that detail.
forman #1445646 03/23/2022 7:38 PM
I think the DBA number is an engine serial number.
D = second series 1946
B = 3100 series (1/2-ton)
A = Flint engine plant
Before 1955 many states title vehicles using the engine serial number.
I looked at the pictures and it’s definitely an Art Deco style truck. Production of these trucks continued into 1947 and many were titled as 47’s.
Professional Novice
Frank50 #1445713 03/24/2022 3:34 AM
Frank, I think you solved it...my head took me to the chassis number, not thinking about the engine number. With the high unit number it makes more sense now...they got the info off of the title!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
forman #1446151 03/27/2022 3:28 PM
forman That truck would be a handful for most of the champs on this sight,hope you have that kind of skill to help !!
