7 members (JW51, baldeagle, Dennys28, Bill Hanlon, Peggy M, Maybellene, Southerntruck),
62
Mod | | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | Im pretty sure this is wishful thinking but is there a way to remove paint without damaging bodywork underneath the paint? | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What kind of bodywork do you mean? Like bondo?
If so, the only thing I have found is elbow grease and caution. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | What Fibonachu said, but you may want to remove the bondo as well. I got a replacement fender that had some up near the headlight. I removed it down to bare metal and fixed the distorted part with hammer and dolly, I don't think that area will need more that a skim of filler or maybe just some high build primer.
You can check for bondo with a magnet. If there is very much the magnet won't stick to the surface.
If the paint is well adhered you can just sand it to feather edges and primer and paint over it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
