2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1446113 03/27/2022 1:50 AM
2 Offline
Im pretty sure this is wishful thinking but is there a way to remove paint without damaging bodywork underneath the paint?
29tons #1446127 03/27/2022 3:55 AM
What kind of bodywork do you mean? Like bondo?
If so, the only thing I have found is elbow grease and caution.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
29tons #1446128 03/27/2022 4:17 AM
What Fibonachu said, but you may want to remove the bondo as well. I got a replacement fender that had some up near the headlight. I removed it down to bare metal and fixed the distorted part with hammer and dolly, I don't think that area will need more that a skim of filler or maybe just some high build primer.
You can check for bondo with a magnet. If there is very much the magnet won't stick to the surface.
If the paint is well adhered you can just sand it to feather edges and primer and paint over it.
