2 members (Phak1, Shade Baby),
71
Mod | | | Forums66 Topics128,139 Posts1,056,448 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2022 Posts: 1 Moderated | | Moderated Joined: Mar 2022 Posts: 1 | I have a 1951 Chevy 3100 that has been restored and now is being reassembled. This process was taking so long that I had to go get the truck from the shop, due to it being there almost five years. During the reassembly, I’ve noticed pieces for the brake and clutch assembly missing, are there any universal kits that will work for my application, clutch and brake assembly from other vehicles that will work? Engine that’s going in is a Chevy 406 small block backed by a 4 speed Muncie. Thanks for any assistance concerning this matter. | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The stock brake and clutch pedal pivot shaft mounts to the frame. Is that what you're looking for. Since you're putting in a different engine, you might want to go with a firewall mount swing pedal assembly that pivots from the top. We need to know which way you're going. If you're looking for the stock pedal shaft that mounts on the frame, send me a PM (after you have a few more posts).
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Several vendors and even ebay sells a nice brake master cyl and booster with pedal assy. These I believe are set up for automatics but you'll need to see what's out there. | | |
