1 members (Samantha), 61 guests, and 4 robots.
Topics128,179
Posts1,057,159
Members48,465
Moderated
Moderated
I have a Chevy 235 straight six engine and the muffler was busted when I bought this truck. Any recommedations for this stock truck with regards to a muffler? Not looking for it to sound like a race car and more interested in a quiet period-like stock sound.
Thank you,
George
George
Contact Waldrons Exhaust , they should be able to provide a stock replacement . I ordered a complete system from them (same as stock system) for my truck. I've attached pics of an OEM muffler and chart with the original component part numbers.
WALDRONS EXHAUST LLC
269-467-7185
Ron - - Dusty53
1954 Chevy 3604
Take some measurements and head to your local farm store. One of their tractor mufflers will fit and sound period correct. Cheaper too.
I run a muffler from Jim Carter, stock type. Not whisper quiet, but that's not how trucks came. Reference their tech article:
https://oldchevytrucks.com/blog/2010/02/muffler-tech/
Sounds really good! PM me if you want a text-message video to hear it.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Moderator, Electrical Bay
The further away from the engine the muffler is located, the nicer and quieter all will be. At least try to get it from right under you. If your muffler is right beneath your cab the vibrations, noise, etc naturally associated with its operation can be irritating. Good luck.
~ Jon
Insomniac
Insomniac
Got mine from Midas. Economizer Plus 89323. Stock type.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
If you get a whisper quiet system, you'll hear all kinds of other noises that you couldn't hear or worry about before.
Including but not limited to your radio and your wife.
~ Jon
George K Did you notice that heat baffle on the bed wood above the muffler ?? Also a tin strap with an elongated eye bolt to clamp the 6 inch muffler to the hanger. This is all repairable at home,like a practical truck should be. Take your snips and cut out a tin strap to fit it,clamp 'er up !!
Martin Good call,always try your farm store first,found everything to modify HEI on my first one !!
Just turn up your radio and/or add a subwoofer under your front seat ... THAT should solve the noise problems of BOTH the muffler and the wife !
Black Bolter
Hillsboro, OR
"We are but a moments' sunlight fading in the grass" - The Youngbloods "Come Together" (circa 1967)
