1 members (Hanks custodian), 122 guests, and 4 robots.
Topics128,096
Posts1,056,482
Members48,444
#1444761 03/16/2022 5:14 AM
Moderated
Moderated
I am new here but just acquired what I think is a Chevrolet C60 with a Napco 4x4 kit. It was a power line truck for years but has been sitting since the 90's.
Tim Schaeffer
3B Offline
Hy Ragnarok, welcome, If you would post the serial number we could get specific, for now your truck is a 1968 through 1972 and I would think at least a 60 series it has the wider front fenders for the larger capacity front axle, hope that helps.
Since Chevy and NAPCO parted ways in 1960, you probably have a 4X4 conversion from another company. Lots of off road rigs were, and still are special ordered for utility companies to service their power lines and pipelines.
Welcome to the Stovebolt wave
Cool truck, what's the plan...tree trimming, parking lot light maintenance?
What year does the title say it is? You can look on the inside of the glove box door for the tech info about your truck.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderated
Moderated
Still waiting on the title but the registration says 1969. Definitely a Napco conversion. The front axle has a Napco tag on it. The glove box tag is badly damaged but here is what I have. CE639P810550 DD
C=Conversion Cab 96” BBC Series 10-60
E=V8 gas
6=GVW range 19000-45000#
3=Hydraulic brakes, chassis cab
9=Model year 1969
P=Pontiac Plant
810550=Unit #
Options on glove box door:
Q64AG 20 x 7.58 tires
H66GG —1850-LB. SINGLE SPEED AXLE 7.17 RATIO
L43GE — 427 V8
F96AA 11000# front springs
660GB — Dual Axle?
N40VD — Hydraulic Power Steering
50DH
5BA
The last four entries are partially obscured.
Pitman Unidyne II Turret-Hot Stik Model HS 46 HA 12
Tim Schaeffer
Interesting truck. In the meantime check out the GVW Tag. Should be on the drivers side door jamb on the back side (under the door striker) at the bottom. Definitely agree that it is a C-60. The VIN Number should also be on that Tag.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Moderated
Moderated
VIN CE639P810550 DD 27,500 GVW
Tim Schaeffer
Ragnarok Have been thru it with Napco used those in spray trucks loaded with liquid in the mud. Tough equipment,once broke a short axle couldn't find one in captivity. My local machine shop made one to fit,sharp people !! On your big one probably find parts the way a power company does. Great truck,Good Luck with it !!
Check the inside of the glovebox door for the build sticker and post a picture of it also.
