2 members (joe apple, jmoore), 129 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#1445158 03/19/2022 11:25 PM
I was looking at a GMC COE today has no title was trying to figure out the vin # info.
Vin FF354 2944
Any help with this would be great.
Curmudgeon
Curmudgeon
Let's see if I can get this correct:
http://www.oldgmctrucks.com/page0010.html
F = 1947
F = Cab Over Engine
35 = 350 Series
4 = Wheelbase 179"
2944 = Regular production series
Does the truck look like the picture?
Close, but using the same web page I'd make it a 1948 because 2994 is between 1054 and 3051 which were the numbers used in '48.
Thanks for the help on identifying the year and series.
Yes the truck looks identical to the picture above.
Looks like something I’d definitely drive!
1952 Chevrolet 6100 2-Ton
Images in the Gallery Forum
Curmudgeon
Curmudgeon
Complicated!
1948 it is.
Here is a 1948. The bed is a little small.....
“The bed is a little small.....” Haha!
I could enjoy a truck like that. Good luck.
Professional Novice
miller ashland Great looking truck,hope you have wheels and rubber with it,because that will be a big expense to get started if you don't. Sort of hinges on overall condition of the whole truck. If it's on rubber and running would help a lot !!
