6 members (GIJOE298, TexasJim50, David Bush, Otto Skorzeny, Peggy M, 1955 1 Series), 82 guests, and 1 robot.
Topics128,154
Posts1,056,851
Members48,456
#14447 05/13/2004 5:40 PM
Just wondering guys... Would the front axle off of a later model 2wd Jeep Cherokee fit nicely under a 46 Chevy pickup? It would be nice if it did to you could modernize the brake and steering systems for cheap. Has anyone tried or thought of it?? Thoughts?
'57 Chevy 210 (235)
'54 Chevy 3800
'49 Pontiac Streamliner (239)
'46 Chevy 3/4-Ton (216) (Sold)
'46 Chevy 1 1/2-Ton (Sold)
'50 Chevy Loadmaster Semi (Sold)
'68 Chevy Stepside (Sold)
I thought the 2WD used an independant front suspension?
Paint & Body Shop moderator
The 2wd jeep cherokee uses a tube straight axle in the front. Looks like the differential was cut out and a tube put in its place. Open knuckle(without axle shafts) design looks pretty sturdy for a light truck.
Yup, That's what I noticed. Does anyone know the track of a stock Cherokee? I don't think it would be hard to weld up some plates to make it mount to the stock springs (Cherokees run coil springs up front). This front end along with an S-10 rear would make braking and steering very reliable and inexpensive. grin
'57 Chevy 210 (235)
'54 Chevy 3800
The Cherokee has a 5x4 1/2" wheel bolt circle, similar to common "small _Ford" bolt pattern.
You might want to think about a rear axle out of an Explorer 4wd or maybe a Crown Victoria, etc if keeping the bolt patterns matching is important to you.
Not sure about the width issue, you might want to take a "tape measure trip" to your local boneyard.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
Or just use the Chrysler 8.25 out of the rear of the Cherokee. Don't want to use a F*** part if I don't have too, even though Chrysler isn't that much better.
'57 Chevy 210 (235)
'54 Chevy 3800
