2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1444866 03/17/2022 1:33 AM
any of you fine fellows tell me what style rims these are ?
Highlander #1444872 03/17/2022 1:53 AM
This should help you ID them.
Link
Highlander #1444873 03/17/2022 1:57 AM
Looks like 2-piece Lock Ring, Motor Wheels to me. Those rims are still servicable by any big truck tire shop.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Highlander #1444874 03/17/2022 2:06 AM
2 Offline
Type AR
3 piece rim, has a square cross section lock ring visible in the photo
You can see the gap of the locking ring
And if that’s a Canadian truck it would be the expected rim at the time it’s virtually the only type I’ve ever seen on these trucks up there in that time range.
Two part rims popped up more later
I also own the widow makers but can’t say for sure which vehicle they came to me on at the moment
But the AR is the most prevalent
-s
Highlander #1444877 03/17/2022 2:35 AM
The rims on my 52 are 2 piece Canadian made Kelsey wheels. No problem getting them serviced by truck shop as said above. Picture shows the lock ring clearly. On the opposite dished in side there is stamped in sizing and manufacturers markings.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Highlander #1444880 03/17/2022 2:57 AM
2 Offline
Yup that ring the split goes to the edge
Not just the split in the smaller locking part
One of the 2 or 2.5 tons I got have some funny rim like that but I don’t use it
It’s sinking into the dirt slowly
I like the three part one because slow and steady gets them apart without much grunting
Just massage it and it will go without much effort but it takes a while to work it all around the bead several trips just working it slowly
-s
2ManyTrucks #1444886 03/17/2022 3:41 AM
Appreciate replies, it is a 48 Canadian Maple Leaf
klhansen #1446709 04/01/2022 2:25 PM
klhansen That rim cross section shows a lot,can't hardly get my x-ray vision to see that with the tire on there. Have a full set of widow makers with 90% rubber on a 51,000 mile truck,so mostly just stay out of their way and use em !
