9 members (chevy51truck, Gdads51, Woodcmiami, KEVINSKI, Peggy M, Wickedbass, Tinker5, Hotrod Lincoln, 1 invisible), 101 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#1444781 03/16/2022 1:36 PM
I was told this is a 1918 truck vin # if anyone can lend a hand on the vin id. Looks like 6R 2013
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Perro #1444784 03/16/2022 1:45 PM
Now there's an OLD STOVE BOLT.
Brian
1955.2 3100 Truck
Perro #1444787 03/16/2022 2:13 PM
I do not believe that is a factory applied tag. Stamping appears much more modern and attached with regular slothead screws.
Perro #1444805 03/16/2022 4:48 PM
When did GM start using clutch head screws? Sure looks original to me based on the rust and stains in the tag. Unfortunately there’s no Vehicle Information Kit for 1918. The 6 prefix indicated the Oakland plant in later years but don’t know when it started production.
Perro #1444808 03/16/2022 4:56 PM
Curmudgeon
Curmudgeon
The first Chevrolet "truck" was a 1918 ton truck.
The vehicle in the picture looks like a "Light Delivery" model to me. The frame is shorter.
Cars and trucks can use the same design tag. The ID tag that says "Four-Ninety" was used from 1916 to 1922.
The tag in the picture looks like those made from 1923 to 1932. Unfortunately the model name is not readable in the picture.
Model names:
1923-26 Superior models (B, B&F, F, K and V)
1927 Capitol model
1928 National model
1929 International model
1930 Universal model
1931 Independence model
1932 Confederate model
After 1932 the tags are a different design
I shamelessly robbed the ACCA of the clipping of the range of serial numbers.
My guess, 1925 Light Delivery. The 6R-2013 could be 6K-2013
A good place to find more information:
https://vccachat.org/
Perro #1444809 03/16/2022 5:13 PM
Nice!
1952 Chevrolet 6100 2-Ton
Images in the Gallery Forum
Perro #1444811 03/16/2022 5:21 PM
Curmudgeon
Curmudgeon
After looking at the windshield I think it is the remnants of a 1925 Canopy Express.
The top right leg of the second character is rounded like an R when zoomed in on the picture. Can't see where that top right leg connects back to the vertical leg, but I'm thinking it's definitely an R.
The windshield is definitely similar in your two pics, but the hood on the OP's truck is longer with very little cowl in front of the windshield. Assuming it's the original hood, it's not the same as the 125 Canopy Express you pictured.
There is a 1918 Vehicle Info Kit, but it doesn't have info on serial numbers. In the last pages there's a discussion on plant production, and the Oakland plant was definitely in operation in '18. Link
There's some pics of a Model T, 1 ton on page 100 that looks pretty close to the OP's truck. If it had a worm drive rear axle and solid rear tires, that would be another confirmation.
Perro #1444822 03/16/2022 6:33 PM
Insomniac
Insomniac
Here's a truck with a "1R" id. I believe that the "1" indicates the plant, so your truck should have been made at plant 6 (Oakland) instead.
https://classiccars.com/listings/vi...e-truck-for-sale-in-auburn-indiana-46706
https://forums.aaca.org/topic/134575-early-chevrolet-serial-numbers/
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Perro #1445604 03/23/2022 2:46 PM
This truck is a 1927 or early 1928. 1928 engine is the only 4 cylinder with two exhaust ports in the head and covers over the push rods. The fenders and aprons are the right type for late 20s.
Mike
1936 1-1/2 Ton (RD) Stake Body Original
