7 members (Opelika Tom, Bigdogg, panel fan, 52Carl, carbking, 1955 1 Series, moparguy),
347
Mod | | | Forums66 Topics128,164 Posts1,057,083 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 5 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 5 | The floor pan (under the seat) has (2) 2" ID holes and (1) 11/16" hole. They appear to be original - are they drain (or vent) holes for the fuel tank? I want to plug these holes since the tank has been re-located, and the available space under the seat is planned for the electrical fuse block and electronics. Anyone know how they were treated originally? And, of course, replacement part information? | | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | Do a quick search online for “electrical ko plugs” (knock out plugs) there is quite a range of styles and sizes (from 1/2” up to 4” at least)that will solve any hole infills you might have very easily. In the floor pan I might put a little caulking so they are water tight. Once you get over 4” look for “clean out wall plates”, they get really big and are stainless or chrome, a 3” clean out wall plate is close to 6” diameter, you just need to make a bar to span the hole to screw them into. Pop in Wing nut tigthten Center Screw tighten (my fav) Etc
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: May 2015 Posts: 11,156 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,156 |
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
