5 members (bnauman, Oswald, 3B, dt235sd, Bill Hanlon), 84 guests, and 3 robots.
Topics128,175
Posts1,057,115
Members48,463
The floor pan (under the seat) has (2) 2" ID holes and (1) 11/16" hole. They appear to be original - are they drain (or vent) holes for the fuel tank? I want to plug these holes since the tank has been re-located, and the available space under the seat is planned for the electrical fuse block and electronics. Anyone know how they were treated originally? And, of course, replacement part information?
Do a quick search online for “electrical ko plugs” (knock out plugs) there is quite a range of styles and sizes (from 1/2” up to 4” at least)that will solve any hole infills you might have very easily. In the floor pan I might put a little caulking so they are water tight.
Once you get over 4” look for “clean out wall plates”, they get really big and are stainless or chrome, a 3” clean out wall plate is close to 6” diameter, you just need to make a bar to span the hole to screw them into.
Pop in
Wing nut tigthten
Center Screw tighten (my fav)
Etc
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Here you go: Link
