0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1444457 03/13/2022 12:53 AM
I had to give the hood of my '48 a pretty good slam to get it closed and latched. I now pull the lever and it doesn't pop up.
Is loosening the hinge bolts in the cab the only way to go or is there another trick?
Thanks!
Former BMW Rider
Former BMW Rider
You can bet you're not the first one it's happened to! grin
Here some related threads.
Let us know how it goes Wally, good luck.......
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Thanks, Andy, Good info there but I got the hood open.
I first pulled the lever all the way out while pushing on the left part of the hood nose sideways to the right. No luck. It was still tight.
Then I pulled the lever and pushed on the right nose sideways to the left. It was loose! I continued to push it around and to the left and the hood came open. I'll now start studying the install and latch adjustments!
Thanks, again.
The funny thing to me is that in the Chevrolet Shop Manual it says to make sure that the 4 bolts on the latch are not tight, and the latch is pushed all the way rearward before closing the hood. It then goes on to tell you that failure to do so will make it impossible to open the hood. End Of Discussion!. No further tips on how to open it!
I guess if it happens, you need to go buy a new truck once it runs out of oil or coolant.
I am adjusting the front sheetmetal and used a flat bar to pry the hood open. I put a rag on the new repop grille and with a little pressure while pulling the release lever got the hood to pop open. I must be missing something with the alignment. maybe I need a gallon of gas and a match. the hood is stuck down again
all I wanted was a pepsi
