4 members (gswbbc, Lugnutz, Dennys28, jmoore), 75 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#1443687 03/07/2022 12:52 AM
I want to repaint the frame on my 1939 3/4 JD. It is painted satin black at the moment, done in 1977. I will probably use spray gun and a brush. What type of paint would you folks recommend? I'm driving the truck to Bowling Green, Kentucky from southeast Michigan next summer for the VCCA 60th Anniversary and want to look my best.
Rick
1939 Chevrolet Stake Truck
rickmg #1444143 03/10/2022 3:28 AM
You might try ALK-200 from PPG auto.
It’s a industrial grade enamel that flows our really well when sprayed and you can brush it on with very few brush marks.
I love it. You can get it in high/semi/low gloss.
It’s about $20.00 a quart.
After your drive, you can just brush in any chips you find. You won’t be able to tell.
It takes about 2 hours to fully dry and about a week to fully cure.
Just remember to prep the surface.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
rickmg #1444179 03/10/2022 3:00 PM
I have also had great luck with ALK-200. Used it on my frame and all my black parts. A hardner is available for it too that makes it even tougher. Doesn't fade in the sun.
