8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#1444015 03/09/2022 12:28 PM
Has anyone ever used a larger diameter with a smaller diameter shaft on a two piece driveline ? Does it matter if they are not the same? I'm working on a 3800.
John L. #1444103 03/09/2022 10:25 PM
I don't believe the shaft diameters being different would cause any problems. The larger diameter would be a little more resistant to twisting (able to handle more torque), but that's about it.
John L. #1444162 03/10/2022 12:11 PM
7
7 Offline
As long as you can keep the U-joints in phase and have a splined slip joint in the rear one you should be fine.
John L. #1444223 03/10/2022 10:06 PM
I recently purchased a three piece driveshaft that has 3" diameter tubing on the first two sections, and 3.5" diameter for the farthest rear section. The first two sections are fairly short, but the last and larger diameter section is twice as long. I'm guessing the larger diameter on the longer section makes it stiffer to help with whipping under higher rpms.
-David
1953 2-Ton GMC
