4 members (oldieoldie, Jon G, 78buckshot, Hotrod Lincoln), 71 guests, and 3 robots.
Topics128,180
Posts1,057,153
Members48,464
#1443776 03/07/2022 9:31 PM
does anyone know the measurements for the front mount holes so I can drill the plate for the bolts to go through? I know the bolt size is 7/16" or whatever, but I am asking about the location of where the holes are at on the mount side to side and how far apart so I drill in the correct location the first time. thank you
all I wanted was a pepsi
H Online: Content
1. Buy a front mount assembly. Most of the resto-ripoff places sell them. Re-using your old worn out mount is probably not a really good idea.
2. Measure the bolt spacing and drill the holes to fit.
i have a new mount.
are the bolt holes centered on the plate? front to back
I guess I will put the engine in using the rear crossmember mounts and set it in place then mark the location of the front mount and drill
I got the engine in and the rear mounts attached to the bellhousing. bolts through the rear mounts and crossmember. I spray painted the underside of the front mount to mark the location I need to drill the front plate after I pull the engine back out.
Does this help?
My Blog
kinda
Curmudgeon
Curmudgeon
thank you that is what I was looking for.
thank you that is what I was looking for. holes are drilled and engine is mounted in my truck with the t5 behind it. I dropped the driveshaft off today also to get shortened 2"
