does anyone know the measurements for the front mount holes so I can drill the plate for the bolts to go through? I know the bolt size is 7/16" or whatever, but I am asking about the location of where the holes are at on the mount side to side and how far apart so I drill in the correct location the first time. thank you
1. Buy a front mount assembly. Most of the resto-ripoff places sell them. Re-using your old worn out mount is probably not a really good idea.
2. Measure the bolt spacing and drill the holes to fit.
I got the engine in and the rear mounts attached to the bellhousing. bolts through the rear mounts and crossmember. I spray painted the underside of the front mount to mark the location I need to drill the front plate after I pull the engine back out.
thank you that is what I was looking for. holes are drilled and engine is mounted in my truck with the t5 behind it. I dropped the driveshaft off today also to get shortened 2"
